Installing new chimney and stove pipe to wonderluxe stove.
ScottChristian
2
Kentucky
Wanting to replace
Old 12.5 in galvanized chimney outer pipe that held the 8 inch single wall,
To a 6 inch ss chimney,. Then into a double wall black stove pipe.
Then to a T section(dvl-t) that connects to stove vent.
Haven't torn into anything yet. But wondering what a huge hole there must be at the roof. Hope it's not much more than 13". But it may be.
Will the flashing that comes with dt620 kit cover such a large hole?
What is best way to make this large hole a tighter fit to a 6dt-60sscf pipe as well as the roof flashing that comes in the kit.....
+- a 15" hole to the duravent 8" diameter
Check with Duravent support. I think the flashing is about 20" wide and 27"? long. If that won't work it may be better to get the parts individually. Duravent makes a large base flashing if needed.
Is this for a different chimney?
I'm ripping out old chimney that had the single wall running up through it. The ceiling box is awful looking at the least Installing new chimney and stove pipe to wonderluxe stove.
