Insulate box with roxul
hamsey Posted By hamsey, Feb 20, 2014 at 8:27 AM
Thread Status:
  1. hamsey
    hamsey
    Feeling the Heat 2.
    NULL
    Jan 3, 2014
    261
    30
    Loc:
    CT
    We have a Regency Hampton in the room above the garage. It has been installed for a few years now. After reading about insulating wood inserts with roxul I am wondering about doing the same with the gas. Before going though the hassle ( I can get to the back of the unit through a small door) would it be worth it? Anything I can do to increase the efficiency I am will to do.
  2. DAKSY
    DAKSY
    Patriot Guard Rider Moderator 2.
    NULL
    Staff Member
    Dec 2, 2008
    6,649
    1,200
    Loc:
    Averill Park, NY, on Burden Lake II...
    What model do you have? Is it a free-standing stove?
  3. hamsey
    hamsey
    Feeling the Heat 2.
    NULL
    Jan 3, 2014
    261
    30
    Loc:
    CT
    No, it is a gas insert. It's the Hampton but it is not listed on the website anymore. It has been installed 5 maybe 6 years now. Looking to see if I can make it more efficient. It has struggled a few nights this winter keeping the room at 68
  4. DAKSY
    DAKSY
    NULL
    Staff Member
    Dec 2, 2008
    6,649
    1,200
    Loc:
    With a gas insert, you can fill the damper area around & between the liners with unfaced fiberglass, you don't need Roxul. You should also have insulation under the cap plate up on top. I wouldn't pack the area around the insert if that's what you're thinking of...
  5. hamsey
    hamsey
    Feeling the Heat 2.
    NULL
    Jan 3, 2014
    261
    30
    Loc:
    CT
    Exactly what I was thinking. Currently there is nothing but air. I will put some on the top of the unit. I have left over roxul from the wood insert install (8 batts). By cap plate do you mean block off plate? Do not have one installed. I will get some photos tonight on the install. Wide open behind and above the unit.
  6. CaptSpiff
    CaptSpiff
    Feeling the Heat 2.
    NULL
    Jan 13, 2014
    253
    46
    Loc:
    Long Island, NY
    Is this gas insert installed in a masonary or a zero clearance FP?
    Are you thinking of placing insulation immediately on top of the insert, or above the damper seal-off plate?
  7. hamsey
    hamsey
    Feeling the Heat 2.
    NULL
    Jan 3, 2014
    261
    30
    Loc:
    CT
    Capt,
    Not installed in masonry or zc. Big open space behind the unit. I have post photos so you can see.
    I was thinking about building a box behind and above the unit with cement board and insulating it with roxul. Right now there is a big air space behind the unit. I know I have to leave a 3" clearance above the unit. Either way I need to wait until we get warmer weather to do this.
    I will try and get photos tonight.
Thread Status:
