Super Cedar firestarters 30% discount
Use code Hearth2024
Click here
Before I seal up the plate I want to add a bit of insulation. At some point this winter I want to insulate that whole space around the liner, but for now just this. I need something I can walk into Lowe's and buy today. What can I put there?
I've been reading this forum for a while (so I know most people on this forum are top-notch in their advice & suggestions), but I only joined last night after I ran into an install road block on my stove insert....
But anyway, my question here is with regard to the current thread on insulation....
I started thinking about the idea of insulation to help improve performance, but the sales associates at my dealer told me that insulation was not necessary because the chimney I was installing my stove into is an internal masonry chimney (stays warmer, better draft, etc)...
However, after removing damper plate and feeding the flexible liner through during the install, (of course I knew this would happen ahead of time, but didn't think to take action on it) I saw the large opening from the where the damper plate used to be on either side of my liner pipe. I said to myself..."Well gee, that's a large open space going up the chimney" and started thinking about the insulation options.
I read somewhere that I can fashion a piece of cement board around the flue liner to and rest on top of my damper edge to block off the opening, so I will attempt this, but would it also make sense to stuff some Roxul above the cement board to keep more heat in?
And I just want to double check...it is totally safe to use Roxul (unfaced, right?) up the chimney like that? I know it's non-combustible to about 2200 degrees, but my wife will kill me if I don't get a definite answer!
Any thoughts comments on this would be much appreciated.
Have been using fireplaces for years, but this is our first stove!
The Roxul is fine. It doesn't burn at 2200 degrees, that is where is starts to get soft. It is what I use at the top and bottom of liners. In direct contact with them.
