    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. lukem Minister of Fire
    Indiana
    My shop has a masonry chimney (chimney block with clay liner) installed on the inside wall. The existing construction has OSB wall what butt flush with the chimney, as does the ceiling. I'm about to blow in cellulose in the ceiling and it dawned upon me that I might have some clearance issues.
    Is the OSB on the walls or ceiling a concern? If so that's a hard fix.
    Any issue with cellulose in direct contact with the masonry. I can build a barrier to maintain clearance but it is cramped for space and I don't want to mess with it if it's not a concern.
    #1
    Helpful Sponsor Ads!
  2. begreen Super Moderator
    South Puget Sound, WA
    I don't know code here, but I thought the chimney was supposed to have a 1" (?) clearance from combustibles.
  3. webby3650 Minister of Fire
    southern Indiana
    A 1" clearance is required by code for Masonry chimneys.
    This clearance is rarely met in most houses though. It's rarely an issue, the few times that this was an issue, well, went up in smoke!;)
    I put a liner in a 30" wide chimney that had a flue fire a few days before I got there. Vinyl siding touched the edges of the block flue, and it was all warped and buckled from the heat the entire length of the chimney. It's pretty scary, keep an inch around that chimney!
  4. Pallet Pete Minister of Fire
    Ovid MI
    It varies by county much of the time ours is 2" requirement most of the surrounding are 1". It may be worth calling the stove inspector to find out for sure. Normally it's the mechanical inspectors department you call.
    Pete
  5. lukem Minister of Fire
    Indiana
    Ha! We barely have permits let alone inspectors. If I'm going to honor the 1" I am looking at full tear out because the outsidebwall is completely touching it. I'll pull back some of the OSB on the wall and see if they left a gap in the structure. Judging by the rest of the poor construction I'm guessing not.
    Pallet Pete likes this.
  6. webby3650 Minister of Fire
    southern Indiana
    The 1" clearance is an IIRC and NFPA code. I don't see how a certain county could require more than International codes requires.
  7. Pallet Pete Minister of Fire
    Ovid MI
    I have no idea as to why What is this wood burners against down drafters alliance ? That sounds like its right up my alley lol.
    Pete
  8. webby3650 Minister of Fire
    southern Indiana
    Oh, just professing my deep hatred for down drafters after my experience with a Lopi Leyden.
  9. Pallet Pete Minister of Fire
    Ovid MI
    Well I might just join you after my Harmon experience lol. Now back to your regularly scheduled thread !
    Pete
  10. tfdchief Minister of Fire
    Tuscola, IL
    Generally, you need 2 in. clearance to combustibles.
