Is it ok to run two pieces of adjustable pipe in a run.
bsa0021 Posted By bsa0021, Oct 19, 2011 at 1:03 AM
Thread Status:
  1. bsa0021
    bsa0021
    Feeling the Heat 2.
    NULL
    Oct 1, 2008
    406
    5
    Loc:
    Ohio
    Iam redoing my stove pipe using Security Secure-Temp double wall pipe (matches the class A). From the ceiling box down I need a 45, 18" straight, 45, 30" straight and stove adapter. They don't make a 18" or 30" straight so I want to use a 12" straight and 3-9" adjustable for the 18" run and a 24" straight with another 3-9" adjustable straight then the stove adapter. This going into a nc13. Is it ok to use two adjustable pipes? Just want to make sure before I order.
  2. webbie
    webbie
    Seasoned Moderator 2.
    NULL
    Staff Member
    Nov 17, 2005
    12,185
    1,087
    Loc:
    Western Mass.
    I see absolutely no reason why not!
  3. fossil
    fossil
    Accidental Moderator 2.
    NULL
    Staff Member
    Sep 30, 2007
    10,552
    2,421
    Loc:
    Bend, OR
    Use as many as you like...they're all rated for use in the flue from stove to the transition to Class A chimney. Once you get it assembled just the way you want it, it's a real good idea to put three screws in those adjustable sections where they end up overlapping, just as you do in all the other piping connections. Rick
  4. PA Fire Bug
    PA Fire Bug
    Feeling the Heat 2.
    NULL
    Jan 13, 2010
    269
    101
    Loc:
    Blair County, PA
    I had to use two curved pipes back to back to get the right angle after replacing my Vermont Castings coal stove with a Pacific Energy wood stove. I was worried abut poor draft or smoke pouring out around the seems. I've fired the stove several times and haven't had any problems.
Thread Status:
