Jotul Firelight 12 CB baffle/blanket replacement
Steve_T
2
Vermont, USA
This is the non-catalytic converter "Clean Burn" model that does not load from the top. The baffles and blanket can be removed by taking off the stove pipe connector on the rear of the stove. Two 10mm bolts with nuts. No need to remove the top. New baffles and blanket that fit the Firelight 600 will fit the stove.
Is that an older model ?
Yes, I believe it was around 2000, when they phased out the Firelight with the catalytic converter. Soon after Jotul changed the name to F600. They screwed the top loading door shut with 4 screws on the inside and added the tubes and baffles. It came with a house we bought and the baffles were burned through but it still heated well so I opted to replace the baffles. Now its like new. It's -15F right now in Vermont and the stove is heating 2000 sf with no problem.
