Jotul GF 600
Cher
2
Barrie
Glass has white film on inside. How do I take out the glass to clean? It is a propane stove. Thanks
Go to Walmart & get a container of ceramic cooktop cleaner, similar to this product (below)
Spread it around with your fingertips, rub harder in the built-up areas & wipe it off with a damp towel.
If your glass has had this condition for more than a couple of years, you may nit be able to remove it completely.
  • Jotul GF 600
Remove the top of the stove, in the gap between the firebox and the doors you should see 2 clamps that hold the glass on at the top. The bottom sits in a track, make sure it goes back in when you replace it.
