Keeping heat in house
antioil
39
Eastern Mass
Hi newbie here and I searched the forum and came up blank.
I have a wood insert installed with an 18' x6" ss liner. The installer capped the top of the chimney and had to of course remove the damper.
Is it safe to use appropriate insulation up where the damper was? He told me it's capped at the top and heat will not "rise out" of the house once the chimney gets warm but I'm thinking why not keep the heat in the fireplace. Thanks
Country wood insert
Welcome to the forum. You could use the insulation, though most everyone on here is going to recommend a block off plate for the bottom. Basically - cutting sheet metal to fit roughly where the damper would have been. This will help keep your heat in and provide for a fire stop in case anything really bad would ever happen in the flue. Search for 'block off plate' there have to be 100's of posts on the how's and why's of using one.
An interior chimney could also benefit from a block-off plate - you can't be sure the top of the flue will remain perfectly sealed to the outside, and you probably will have some convective flow in the chimney even if that seal is good. The heat may not be lost to the outside, but it may not be going where you want it, either. Mineral-fiber insulation will still allow some air flow, so a metal plate is a good addition to that. Installers don't seem to be interested in doing them that often, so don't feel bad.
On an exterior chimney you are going to lose heat to the outdoors, not just to the upper levels of your chimney. That is especially true if your liner is not insulated and there is lots of air space. As warm air rises, the air on the exterior, cold side of the cavity will fall. As heat moves from hot to cold, the upward moving warm air wants to transfer the heat to the outside, and creates a convective loop inside the chimney. It is constantly dumping heat to the cooler, external masonry and then to the great outdoors.
antioil said:
Thanks...block off plate it is...now to find someone to do it. Any suggestions for eastern Mass Boston area?
A block of plate is a pretty easy project. I believe that this site has a "how to" if you are a diy kinda person.
If you're not a DIYer, show the how-to article to anyone who likes to play with metal and tools - they don't really need to know jack about stoves and flues as long as they know your objective.
I jsut bought some insulated blinds for my downstairs. Cost me $200 for 4 blinds. They "say" that you should have blinds in your windows for draft etc. My windows are double pane but not argon filled etc.
