So the Kenmore Elite Front load washer started making noise when in a high speed spin. Had an idea that it was the bearings. Pulled off the back cover and the pulley wheel and sure enough the bearing assembly shows massive wear. Some of the ball bearing are shot. Tried to get a part number from a sears website but the website doesn't show the bearing assembly as a separate part. Not sure if it is considered part of the outer tub. Has anyone had this problem and how did you find the correct part.
