georgia said:
Well that kinda scared me about the R-value of the original brick hearth so I went and measured the chimney down in the crawlspace of the house. (The chimney is central to the house and serves two back-to-back fireplaces.) The brick hearth sits on cinder blocks that go all the way down to dirt so I'm safe there.
Sounds good, just make sure they don't pass any floor joists through the blocks or attach them to the blocks. Hopefully they don't but it's not unusual to see that.
[/quote]Gooserider, I searched around - is yours the sort pf pyramid shaped brick fireplace with multi colored slate in front ? Pretty cool looking. But I think I'd like to put something in that matches the existing hearth - so I guess I need to start searching for some sort of brick veneer/paver that comes close and get it as flush as possible. I guess now's the time to see about reinforcing a joist or two to see if I can take some sag out of that floor. As with all projects, it's one layer after another. And I thought we were going to just pop in this perfect-fit insert. Hah.[/quote]
Yes, though we call it the "Brick Rocket" :coolsmile: The slate was chosen because we have a front entryway that doesn't show in the photos, but is just to the left of the hearth, using the same style of slate. The left end of the extension actually ties into it. We decided that rather than using some sort of tile, it would be best to match the slate and minimize the number of different materials in the room. It worked out to be an almost perfect match except that I wasn't able to get the grout on the old slate as clean as I would have liked, so it is darker than the new slate :long: I can live with that...
You will need to make sure the floor under the extension is stiff enough, if there is excessive flex the flooring will eventually fail. The John Bridge tile site does have a calculator to let you figure that. If you have access to the joists underneath, the easiest way to stiffen things up is just to sister the joists in question.
[/quote]So now let me ask this. THe hearth is about 55 inches wide x 14 inches deep x 8 inches high. We'd like to get a stove in sooner than next winter, and its clearly going to take us at least a month or two to get the extension figured out and completed. Would it be safe to extend it twmporarily with a piece of stove board attached to the wood floor, and finish the job when we get the materials and design together? Would this live up to code requirements?[/quote]
Not sure what you mean by "stove board" but I would think that a layer or two of Durock would do it, or possibly (albeit more expensive) a pre-fab hearth extension... More importantly you might want to talk to your local inspections people to see if they will buy off on something like that. Sometimes there is code, and then there is how the code people interpret it, so it helps to ask first and avoid headaches later.
Gooserider
