We have a strange lamp in our laundry room. It has a 60W incadescent bulb and the filament continuous glowing in orange even when the light switch is turned off; similar when turning a dimmer to a very low setting. However, the lamp is on a single standard wall switch. I am thinking of just replacing the switch to see if that solves the problem but before I do that I wanted to call on the DIY wisdom here before I screw up anything. Did someone have something like that before? Should I better call an electrician because it could be a larger problem? Many thanks!
