richkorn said:Flame needs to stand up. If you push in the damper rod the flame gets lazy and sort of flops around. Pull the damper rod out to get some more air and you can see it stand up and get more active.....
imacman said:richkorn said:Flame needs to stand up. If you push in the damper rod the flame gets lazy and sort of flops around. Pull the damper rod out to get some more air and you can see it stand up and get more active.....
As for the OP's question, the video that philbrick provided above has some good examples of good and not-so-good flames. The first 2 examples of lively flames on med and low are VERY similar to what I see in my 10-cpm.
And for nhredbird, optimum settings are subject to different stove set-ups, exhaust set-ups, and pellets used. The factory lower button settings of 1-4-1 are a good starting point. When it gets really cold, I bump them to 2-4-1, or 3-4-1 for more heat. Then, just adjust the heat & fan control to suit your needs.
nhredbird said:Imacman, I didn't know you could change the bottom 3-buttons.
The manual states not to change them they are factory set?
Can you better discribe how to and what they do.
In the 3-settings you you talk about, your only changing the first number?
Another question i have is using a t-stat, should i use theirs or do you recomend another?
Thiers comes with specific instructions?
The manual also says to leave the heat range at 5-5 when using the stat?
Its still not cold enough to let this thing run for any length like I,m sure it will & should.
Just trying to better understand it.
bd911 said:On the EP the bottom three effect on all heat settings. ( according to a conversation with tech support last season)
nhredbird said:After doing a search, i did find alot about this.
I don't think i have any problems.
It looks now, i will wait for it to get colder and spend a Sat. making minor changes.
nhredbird said:.....The manual also says to leave the heat range at 5-5 when using the stat?
nhredbird said:Was 63 in the house last night ran the stove on 5-5 for 2hrs brought the temp right up to 68.
It was only 52 outside.
Wife was happy.
I took a measure of discharge air temp was only 140, thought after a couple hrs would be hotter?
Flame is up high on start up, then settles down to 2" to 4" above pot.
When i shut it down it only takes 8-10 min to cool and all fans stop.
I like the stat, thanks.
Looked at the back of control unit saw the words thermosat, is the jumper to be removed, the small bare silver wire on bottom?
Which 2-terminals are used on the stat?
nhredbird said:....Which 2-terminals are used on the stat?
