Hi all,
On the advice of another member, I am reposting my thoughts/experience from another thread and starting a new one. The original thread outlined my trials and tribulations surrounding the operation of my new Woodstock Fireview.
“I thought I’d report back on my progress. Using your suggestions, I was able to achieve much better results than I was previously getting. However, the one variable I couldn’t change was the fuel. So, I walked down the street and asked one of my wood-burning neighbors about his wood supply (red oak) and he assured me it was dry as a bone (3-years; top-covered). He was kind enough to give me a wheelbarrow full for my experiment. Great neighbor…great guy. I loaded into my stove and used the same techniques I’ve adopted from you guys. After about 10 minutes I engaged the Cat and set the draft to 1 for a bit (normally I set it to 1.2), but after several minutes I dialed it down to .75. Normally this would kill my heat output. I’m sure you won’t be shocked to hear that the results far exceeded what had become the standard over the past months. The stove has been hovering around 500F for about 2 hours…something that it has never done before. Also, the firebox is filled with dark-red embers and no flame (like you guys keep talking about). So, not only is the stove burning hotter, it is also burning longer. I’m sure I can still fine-tune some of my technique, but I’m obviously on the right path.
I consider myself a fairly methodical person who prepares adequately for projects/tasks/etc. Therefore, I thought I was way ahead of the game when I picked up 9 cords of “seasoned” wood in the middle of last summer. Mostly oak (for better or worse). I still had several months to further dry the already seasoned fuel, right? Yes, but it wasn’t close to enough (damn oak). [***EDIT*** The "seasoned" wood I have measures approximately 22-28% with regards to moisture content (readings taken from freshly split pieces).***EDIT***] If there are any of you that are reading this that are new to wood burning (Cat stoves in particular), please learn from my mistake. As a group, why do us newbies keep making this error even with this plethora of great advice at our fingertips? Take the advice of those who have been there and done that. It will save you time, money, effort and frustration. The importance of dry wood cannot be overstated. It is crucial to getting through the winter at an acceptable level of efficiency. If the wood is improperly seasoned, it burns cooler and shorter. With improperly seasoned wood, you can forget about those 8-12 hour burns the Fireview owners tout. Those results cannot be reached without an adequately dry fuel source. If you’re thinking about getting a Fireview…don’t let this detract you. Quite the opposite, the results that this beauty can achieve with the right knowledge and materials is astounding. This includes, very long burn times, low fuel consumption, wonderfully soft heat. I LOVE this stove and I would buy another in a heartbeat. Ah, and when next year comes around, and my wood is dry, dry, dry, I am going to love it even more!”
I hope that my lessons learned due to my ignorance associated with the importance of truly seasoned wood helps others avoid some of the frustration I've encountered. Good burning to all.
