Liberty primary air control cleaning
boisblancboy
149
Northern Michigan
I think that the opening for the primary air inlet(in the center/front of the firebox) is getting a little clogged. Does anyone have any tips for cleaning this path way out? I know the air is drawn from the bottom of the stove and makes it way to the outlet I should say right inside the door. Would compressed air help clean any ashes that have settled in there? Any advice is welcomed!
i have used an air compressor and a regular vacuum. Most of the time I just vacuum the air inlet. If you do use an air compressor it is going to make a huge mess.
