    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
Thread Status:
  1. elkimmeg Banned
    The draft meter is at the post office addressed to you, good luck and let us know how it worked out. Add the 10" single wall to raise
    the baro damper and you will need to drill a hole in the pipe to use the tester. I would just thread in a short bolt in the hole afterwards
    Baro dampers add weight allows more, reduce draft lessens the weight
    #1
    Helpful Sponsor Ads!
  2. lime4x4 New Member
    Northeast Pa
    Thanks..So basically once i set the draft to .04 the barometric dampner will basically adjust to maintain that draft??
    Thanks Once again
Thread Status:
