    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
Thread Status:
  1. Jaamz New Member
    I'm installing a 316 steel flex liner in my basement fireplace chimney, which is more or less directly below the upstairs chimney. Because of this, there is rather severe turn in the existing terracotta liner. I have the liner to this point and can't seem to make the turn to continue. Seems like a common enough problem, but I haven't figured out the common solution. I'm using a pull con from the bottom with a rope and pulling the liner through the chimney.
    #1
    Helpful Sponsor Ads!
  2. elkimmeg Banned
    You should move this post or repost in the hearth room there many can offer suggestions
    they may not see it here
Thread Status:
