    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. KarlFF New Member
    Michigan
    I recently inherited a Vermont Castings ("V.C.") Radiance Model 2600. I really want to use this stove as I've admired it for years, but cannot track down a conversion kit #5093 for the stove. I have gotten the full story from my local V.C. retailer and several online sources. V.C. has been sold/purchased several times in the past decade and the newest owner is no longer supplying the parts for the Model 2600 stoves. The stove was manufactured, I believe, by CFM and the gas fittings/orifices were supplied by Honeywell (I understand that Honeywell no longer makes these parts).
    Does anyone have this kit or have any ideas as to where I might find it. I'd be willing to pay for used parts to convert this stove. Bringing natural gas to my house is not an option for me.
    Thanks Very Much, Karl
    #1
    Helpful Sponsor Ads!
  2. DAKSY Super Moderator
    Try contacting Monessen...Either a dealer or online, or PM Dave Gault (Wood Heat Stoves) in this forum...
    Should be about $100 if you can get it...
    HTH
  3. KarlFF New Member
    Michigan
    Thanks very much, Bob. Will give those options a try.
  4. cdnxj New Member
    Ontario Canada
  5. KarlFF New Member
    Michigan
    This kit has a different number than 5093. In all probability, would this kit be usable on the Radiance Model 2600?
  6. Fsappo New Member
    Central NY
    I wouldnt trust that the part numbers stayed the same with all the crap VC has gone thru. Call little Eddie Drexel at the Cozy Cabin and have him determine the proper kit for you
  7. k0wtz New Member
    missouri
    i have a radiance 2600 in n/g. i wonder if we can swith parts as i want to chang to propane.
    let me know by p/m
    thanks
    bob
  8. k0wtz New Member
    missouri
    i have spent quite a bit of time trying to find the lp conversion for this stove as i just purchased one in mint condition. there is nothing available now i am at the point of contacting my furnace guy to see if this can be adapted some way.
    anyone done this?
    thanks
    bob
  9. fireplace tech New Member
    northern, ohio
    i 'm working on locating that conversion kit for you ,i will post back with answer.
  10. DAKSY Super Moderator
    I'm thinking that the only way you may be able to do this is to change out the entire gas valve. It's gonna cost ya, but you should be able to get plenty of parts...Somebody at Monessen/Majestic/VC Tech should be able to tell you what's compatible with what you have in there now...
  11. k0wtz New Member
    missouri
    ok thanks a lot. this stove is just beautiful and looks brand new.
    thanks
    bob
  12. k0wtz New Member
    missouri
    i looked for your company but i dont see them. do you have their phone nr.?
    thanks
    bob
  13. k0wtz New Member
    missouri
    ok
    i did a search of propane gas valves. i see some that should work. is my stove a millivolt system? would anyone have some suggestion?
    any help greatly appreciated
    thanks
    bob
