LPG Boiler Placement
huffdawg Posted By huffdawg, Feb 9, 2011 at 5:27 AM
Thread Status:
  1. huffdawg
    huffdawg
    Minister of Fire 2.
    NULL
    Oct 3, 2009
    1,390
    100
    Loc:
    British Columbia Canada
    Just curiuos, does anyone have their LP boiler in the same boiler room as there woodfired boilers.
  2. heat4steve
    heat4steve
    Member 2.
    NULL
    Jul 15, 2009
    65
    0
    Loc:
    Rochester Ny
    I have my LP boiler within 4 ft of the wood boiler. Here there is no code against doing so - at least my building inspector is fine with the setup. However my father inlaw is completely against because of the potential ignition source if there is a propane leak. To me either it is safe to use LP in the house or it is not since there are a multitude of other ignition sources (electric switches, lights, etc..). Obviously the two boilers cannot share a common chimney.
  3. in hot water
    in hot water
    New Member 2.
    NULL
    Jul 31, 2008
    895
    2
    Loc:
    SW Missouri
    It depends also on the type of LP boiler. Sealed combustion boilers are best for several reasons. The burner is sealed and enclosed, no open flame and combustion air drawn from outside.
    Sealed combustion also it eliminates the potential for all that airborne ash getting drawn into the LP boiler.
    Since LP is heavier then air, an LP gas detector is required in some areas, if the boiler located in basements, or low areas. A LP along with a CO detector is always good insurance.
    hr
Thread Status:
