    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. Eatonpcat Minister of Fire
    Eaton Township, Ohio
    I broke something on my Hopper lid slide last night (I think). The lid pulled out about six to eight inches and got stuck, so I used a little persuasion and yanked it open. Closed the lid and then it would not open passed the 6 to 8 inch mark again, so in my pie eyed state, I yanked harder and heard something fall to the Hearth. I found a small steel ball, assuming it's a slide bearing of sorts. Being it was throwing heat on level 3 and I was at least 1.5 sheets to the wind, I did not explore the problem much longer. Since I could not get the lid open far enough to turn the stove off, I removed the bolts that hold the lid on and shut her down.
    Anyone have any experience with a similar problem, I am all ears??
    #1
    Helpful Sponsor Ads!
  2. Delta-T Minister of Fire
    NH
    7 inch drawer slides...gonna need a new set. Seen it a few times, probably a pellet or something got in there. Not a hard fix, but annoying. You'll have to remove the lid, and then it'll all make sense.
  3. Eatonpcat Minister of Fire
    Thanks, that is kind of what I figured, but it's always good to hear from the gals and guys on hearth.com
  4. Delta-T Minister of Fire
    NH
    I've seen the rope gasket for the hopper cause the same thing, again, once you get the lid off you'll see it all pretty clearly.
  5. Delta-T Minister of Fire
    NH
    its always nice to help the people who like to help people....Go Team!
    Eatonpcat likes this.
  6. jtakeman Minister of Fire
    Northwestern CT.
    You didn't sit on the poor thing did ya? :p
    Still under warranty?
  7. Eatonpcat Minister of Fire
    Didn't sit on it JT, But I had been resting the pellet bag on it when I filled it. As far as warranty goes, I believe it was my fault, so I bought a slide ($7.00/pair at rockler) adapted it to fit and installed it. It works, but I will now look for the exact slide and replace it!
  8. Eatonpcat Minister of Fire
    Yeah been looking all weekend for the sunflower seed button...Finally found it and when my dog walked by she burst into flames!!
  9. smoke show Minister of Fire
    Pittsfield, Wi
    Only cool stoves have options like that...
  10. SmokeyTheBear Minister of Fire
    Standish, ME
    Have you been dancing again?
    smoke show likes this.
  11. boblo45 New Member
    Southeastern CT
    I had a similiar experience just two weeks after purchase, which was about a year ago. You will need to replace the metal slides on both sides of you insert that attach to the lid. This is not difficult to do. Your owners manual should help identify the part number you will need to fix the problem. They come in pairs. In the interim, I put the ball bearings back into the slide that broke, which can be tricky to do and waited for the new parts to show up. Bear in mind that this is a temporary repair until the new comes in. The slide will eventually break down again due the initial metal fetague. One special note, when filling the hopper, carefully lay the bag on the cover/lid. If you drop the back onto the lid the weight itself will pop the ball bearings out of the slides.
  12. Eatonpcat Minister of Fire
    Thanks Boblo...I just got a set of 10" slides at Rockler and drilled the holes I needed for the lid bolts and the connection to the stove box.
  13. Eatonpcat Minister of Fire
    On the M55...Heat level 3 = Turbo (Sunflower seed) on the Quad!
  14. boblo45 New Member
    Southeastern CT
    I don't need one. Mine works just fine! Mine heats 1850 Square Foot Colonial just fine. I also use the air handler from my AC unit (in the attic) to circulate the heat around the house. Makes a big difference.
  15. Eatonpcat Minister of Fire
    Some folks can be fooled by your smoke and mirrors...You had a M55 owner there...Probably buying pellets for a good price and he was being nice to you...He Pm'd me and said he was freezing at your crib!!;)
    oldmountvernon likes this.
