Making your own pellets
heaterman Posted By heaterman, Jun 5, 2013 at 9:47 AM
Thread Status:
  1. heaterman
    heaterman
    Minister of Fire 2.
    NULL
    Oct 16, 2007
    3,355
    622
    Loc:
    Falmouth, Michigan
    I have a client that owns a cabinet making shop who is looking for a heat source other than LP Gas for his spray booth make up air. (1/2 million btu's)
    They obviously generate large quantities of sawdust and it runs about 6-10% moisture content. I'm thinking a possible scenario might be for him to install a pellet boiler or two and make his own pellets but I have no idea of what is involved machinery wise for pressing the pellets.
    Any of you guys have experience or know of manufacturers of this type equipment?
  2. smoke show
    smoke show
    Guest 2.
    NULL
    The general consensus is its not worth it. Do a search, its been discussed many a times.
    will711, StihlHead and Eatonpcat like this.
  3. Jags
    Jags
    Moderate Moderator 2.
    NULL
    Staff Member
    Aug 2, 2006
    17,509
    6,077
    Loc:
    Northern IL
    Maybe cut out the middle man and move up to a sawdust burner?
    Delta-T and Eatonpcat like this.
  4. heaterman
    heaterman
    Minister of Fire 2.
    NULL
    Oct 16, 2007
    3,355
    622
    Loc:
    Falmouth, Michigan
    Well that's what I'm trying to figure out for the guy. Bear in mind that he has mountains of sawdust already made as a byproduct of his business. Nothing further needed other than pressing it into pellet form.
    M/C runs 6-10% as produced so he'd probably have to add some water to get to 10-15% for good processing.
  5. Delta-T
    Delta-T
    Minister of Fire 2.
    NULL
    Feb 27, 2008
    3,144
    580
    Loc:
    NH
    the numbers don't really work on a scale that small. you could get a cheap pelletizer, something for animal feed, and run it on a small HP engine, but the pellets wouldn't be sufficently dense to burn correctly in a commercially available pellet boiler. you have to get the pellets to come out of the die at greater than ~64 lb/ cu ft...which isn't easy. I've seen things done on that scale in briquette form, with purpose built equipment = pricey. Even pellet mills will just go ahead and burn sawdust for steam and hot air, rather than process into pellets and burn. If your friend also has a large water wheel attached to a shaft that is being under utilized, well, then we might have a different scenario;)
    smoke show likes this.
  6. jtakeman
    jtakeman
    Minister of Fire 2.
    NULL
    Dec 30, 2008
    13,497
    1,573
    Loc:
    Northwestern CT.
    I have seen a burner that was a retro fit to an industrial boiler. It can be fired by Several fuels including sawdust and planer chips. They also make complete systems as well.
    http://www.leiprod.com/leiproducts/
  7. mepellet
    mepellet
    Minister of Fire 2.
    NULL
    Aug 10, 2011
    2,141
    276
    Loc:
    Central ME
    Yup. Seems like this topic comes up several times a year and no one has gone through with it for one reason or another.
  8. welderboyjk
    welderboyjk
    Member 2.
    NULL
    Jan 29, 2009
    36
    1
    Loc:
    South West, Michigan
    Why not look into some sort of heat recovery on the outgoing air? I believe there are commercial units available and probably cheaper (I.E. DIY) varieties that can be made.
    Tedinski likes this.
  9. heaterman
    heaterman
    Minister of Fire 2.
    NULL
    Oct 16, 2007
    3,355
    622
    Loc:
    Falmouth, Michigan
    After doing some research on the cost of a mill large enough to produce pellets at a reasonable rate and considering the labor/time involved, I can see why few are actually doing this. Very labor intense for mills that will only crank out >500 pounds per hour.
    Poor ROI.
  10. heaterman
    heaterman
    Minister of Fire 2.
    NULL
    Oct 16, 2007
    3,355
    622
    Loc:
    Falmouth, Michigan
    There is virtually no heat to recover once the hood runs for a minute or two. Visualize a building the size of a small ranch home with 10,000CFM being pulled through it while it's 0* outside and you can form a mental picture of the environment they are spraying in right now.
  11. mepellet
    mepellet
    Minister of Fire 2.
    NULL
    Aug 10, 2011
    2,141
    276
    Loc:
    Central ME
    First step may be to confirm the hood is correctly sized.
  12. ScotL
    ScotL
    Feeling the Heat 2.
    NULL
    Feb 7, 2011
    376
    136
    Loc:
    Central Maine
    Industrial burners do not burn the pellets in their pellet form anyway. They are ground up first. With a wood suspension burner and a grinder to grind your sawdust into a flour you could use the dried sawdust just the way it is without pelletizing.
    For 500,000 BTU/hr you would need about 65 lbs of dust per hour. Since your moisture is just a little on the high side (but still great for a suspension burner) maybe a little more than 65 pounds.
    The only problem is, I don't know if anyone makes a wood suspension burner that small. I have seen solid pellet burners in that size range - we have a 600,000 btu boiler here - but I haven't seen suspension burners that small. You could probably get a biomass burner that size but it would have to be designed for your lower than normal biomass moisture fuel.
  13. saladdin
    saladdin
    Feeling the Heat 2.
    NULL
    Dec 29, 2011
    345
    66
    Loc:
    West Tennessee
    MIL has her own cabinet business (and other things like mantels, cabinet doors...you get the picture) and it's not worth it to them to make the pellets. They have tons and tons of sawdust.
    Most on this forum have friends or families that have access to tons of sawdust and none of us can find an efficient way of doing it. Doubt you are any different. Unless you just have thousands to dollars to burn and a lot of extra time to do it.
  14. heaterman
    heaterman
    Minister of Fire 2.
    NULL
    Oct 16, 2007
    3,355
    622
    Loc:
    Falmouth, Michigan
    The equipment to handle/burn dry sawdust is out there but very pricey for a project of this scale. Probably talking $75K+ including the storage bin and feed auger.
    Of course.....if he goes with an LP gas fired makeup air unit, that thing will suck down LP at the rate of about $24/hour
  15. hoverfly
    hoverfly
    Minister of Fire 2.
    NULL
    Jun 26, 2008
    550
    17
    Loc:
    Southern NH
    I forgot the name of it but how about piling the sawdust on top of a circuit of pex tubing and collect the heat from decomposition? Sell the compost during the summer to local gardeners and/or landscapers? Maybe bag it and sell it that way as well. If not just dump it in the back yard.
    Ah here we go Compost Water Heater from Mother Earth News.
  16. Lake Girl
    Lake Girl
    Moderator 2.
    NULL
    Staff Member
    Nov 12, 2011
    6,492
    1,329
    Loc:
    NW Ontario
    While looking around, came across the Curran Renewable Energy installation. A little big for the OPs needs;lol
    http://www.energyunlimitedinc.com/photogallery.htm
    The LEI products are interesting ... how costly though? The manure processing equipment would be an economic bonus for cow and horse farms ... depending on the costing. Wonder what size farm would be the break-over point economically speaking.
Thread Status:
