    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. Merrill New Member
    Hello Coaly: Acquired a little used Mama Bear about 30 years ago. I stored it in the basement and did not use. Until now! Or will use it after my new outside shop is completed. I have the firebrick in a box (took out of the stove to save weight in moving - Duh!) and now need the layout for the brick, as you showed for the Papa Bear stove a couple months ago. Except for the Mama Bear. Do you have such?
    Also in reading the Fisher thread, there is talk about adding a baffle. My stove is not the older one, but it does have a square opening and square door. And no inside baffle. Just a plate beneath the 6" flue. Can I add a baffle? Should I?
    Any help will be very much appreciated. Thanks in advance.
    #1
    Helpful Sponsor Ads!
  2. coaly Fisher Moderator
    NE PA
    The brick layout is in the Mama Bear Firebrick thread here;
    http://www.hearth.com/talk/threads/mama-bear-firebricks.88386/
    And the baffle pictured in this thread is in my Mama Bear that worked out very well sitting on the small horizontal plate below the outlet. 2 firebricks stood upright on the sides supports the front of a solid steel plate on an angle that directs the flame to the stove top, instead of out the rear outlet.
    http://www.hearth.com/talk/threads/...d-fisher-more-heat-less-smoke-under-25.74710/
  3. Merrill New Member
  4. Merrill New Member
    Thank you very much the the helpful reply and information.
