we've finally enough of a warm up here for me to allow the stove to completely cool (englander nc-13) so i did a thorough ash clean out and inspection from the bottom. took the baffle plate out and saw some creosote had fallen on it. early in the season, we had trouble seasoned wood that had been rained on and hissed and spit quite a bit. i had another load brought of barn-stored dry wood to get things hot then i throw on one of the damp pieces and had been having pretty good luck since. however, i was surprised to find the creosote. i consistently burn seasoned wood, always. i tapped on all of the single wall stove pipe i could reach and more fell down, probably enough to fill a 1/2 gal jug. shiny little chips of the stuff. i considered getting on the roof and doing a cleaning, but it's been raining all day. maybe this coming weekend will allow it.
when i had this stove installed last year, the guys installed class A chimney straight up through the roof with all of the proper heat shielding where it passes through combustible areas. i do pretty well burning efficient fires and usually just see the heat 'shimmer' at the top of the chimney and very little smoke except when it's just getting started or cooling down. when the install was done, one of the techs told me that while it was important to sweep frequently, in the event of a chimney fire, it would just burn itself out as it consumed the creosote and wouldn't likely catch the rest of the house on fire. now obviously i'm doing every thing to prevent a chimney fire in the first place, but i'd like to see what others think about that above statement. thanks.
