I wish to install a 40,000btu DV insert...use as back up to very inefficient heat pump in a 2500sq ft house.
Our fireplace opening is 33 7/8" wide.
We are looking at either Mendota FV44i (requires min fireplace width of 34") or HeatNGlo Escape 135FB (min fireplace width of 35")
One installer was reluctant to install the Mendota as dimensions were so tight.
Is it possible to shave some of the fireplace brick on side to accomodate the larger dimension? It appears to be straightforward to me. It likely only needs to be done for approx 3" back into the firebox as most inserts taper.
Thanks
Thanks
