This has been discussed in other threads but Jay and I thought it should have it's own home. A pellet stove generally has many adjustments. I compare it to a carburetor on an engine. (remember them?) With an engine, you can see the results to your adjustments in power output or, if you have an exhaust analizer, how clean the exhaust is. With a pellet stove, you have the visual check. How the flame looks, how the pellets burn, how much ash, and how hot the air feels coming out of the vents.
I love information, the more the better. I used the tried and true meat thermometer but I longed for something more accurate. It was so slow to react. My solution, thanks to the company I work for, was to get a LED temperature controller that no longer controlled. All I wanted was the temp readout anyways. I put the thermocouple in a discharge tube and now I have a precise handle on how hot the air is coming out into my room. I was absolutely amazed at the diffence in air temp with just the smallest of air adjustments. I found exactly what a change in feed rates did and what fan speed gave me the best heat output.
I thought about what could be used in place of a digital readout. My thoughts were that an automotive temperature gauge would work. Not the electric one but the old mechanical gauge. It would be easy to install in an enclosure by using a hole saw to cut a 2 inch hole. They usually go up to 280 degrees. If anyone is interested, they can be bought cheaply at stores like JC Whitney.
http://www.jcwhitney.com/Water_Temperature_Gauges?ID=7;1101006168;0;0;100001;Category;0;0;0;0;0;0;0
Anyone else have any alternative ideas?
Chandler
Chandler
