My pellet stove exhaust has stained my exterior vinyl siding..how can I clean it off?
tundraSQ Posted By tundraSQ, Apr 19, 2008 at 2:25 PM
Thread Status:
  1. tundraSQ
    tundraSQ
    New Member 2.
    NULL
    Oct 7, 2006
    151
    0
    I tried searching here and google and I have not found the answer. I have a power washer and I plan on using that. Water alone will not touch it. I tried the stovebright glass cleaner and that didn't work. I have read about TSP and plan on trying that....is there something else I should be trying?
    Tim
  2. fletchtb
    fletchtb
    Member 2.
    NULL
    Jul 31, 2006
    57
    0
    Loc:
    Fletcher, Vermont
    I've heard you don't want to pressure wash vinyl siding. I think it was because water can get behind the vinyl and cause problems with wood behind it.
    With that said, I have the same problem you do. I bought a gallon of a product called Greased Lightning that was okay. I also used some Soft Scrub and it was okay too. I still have some grey soot in the little crevices in the vinyl. I was thinking of trying some TSP too.
    Overall, I spent a lot of time working on the siding this weekend and it looks 80% better, but it still has quite a ways to go before it is the way it was before we go a stove.
    We have wondered whether we could paint the vinyl each spring???
  3. Turbozcs2003
    Turbozcs2003
    New Member 2.
    NULL
    Apr 3, 2008
    80
    0
    Loc:
    southernMaine
    How do you guys vent yours??
    Is your exhaust too close to the siding? How far away did you terminate from the wall.
    I would try some of TSP with a strong detergent.
  4. billb3
    billb3
    Minister of Fire 2.
    NULL
    Dec 14, 2007
    4,375
    617
    Loc:
    SE Mass
    Even if you use just hose pressure you should be careful not to hit it too hard and aim down so water never goes up under the shingle. Same at seams and ends, low pressure and aim down.
  5. kinsmanstoves
    kinsmanstoves
    Minister of Fire 2.
    NULL
    Aug 29, 2007
    3,480
    501
    Loc:
    Ravenna, Ohio 44266
    One of the causes of heavy sooting is incorrect venting or clogged venting. What are you using and what does your exhaust consist of?
    Eric
  6. MainePellethead
    MainePellethead
    Minister of Fire 2.
    NULL
    Dec 9, 2007
    904
    0
    Loc:
    Southern Maine
    I use Bleach on my siding....I dont have a prob with sooting.....but have always used bleach to clean mildew and other stains....I bet you'd have good luck with bleach. :)
  7. RedRanger
    RedRanger
    New Member 2.
    NULL
    Nov 19, 2007
    1,428
    0
    Loc:
    British Columbia
    Ever heard of ZipWax car wash and wax? Try it,works great on vinyl siding.
  8. nailed_nailer
    nailed_nailer
    Minister of Fire 2.
    NULL
    Oct 29, 2007
    861
    130
    Loc:
    Cape Cod, Ma
Thread Status:
