Good day. I've been operating my Central boiler for 10 years with no problem. The boiler is about 75 feet from my house and heats a concrete floor. This summer I am building a barn which I also intend to heat via pex in a concrete floor. My problem is how to get cold water to the barn to mix with the hot water from the boiler. My well is about 250 feet from the barn and getting cold water from the house to the barn would require drilling into my concrete floor filled with pex or the concrete foundation - both options aren't ideal. An engineer friend suggested taking the cold return from the house and instead of returning the cold water to the boiler, run it in the ground without insulation (to cool it down) and use it as my cold water supply for the barn. The end result would be two supply lines coming off the boiler (one to house, one to barn) and only one return line coming from the barn. My concern is that connecting the two systems sounds like a problem waiting to happen. Any suggestions would be welcome.
![[Hearth.com] Need cold water to mix for new building [Hearth.com] Need cold water to mix for new building](/talk/proxy.php?image=http%3A%2F%2Fs3.supplyhouse.com%2Fimages%2Fproducts%2Flarge%2Fam101r-ut-1-1.jpg&hash=063e54adc1ed9d5390d5e793cc85a149)
