I have a 40 x 64 shop all with radiant in slab heat. The "Toy" side of the shop is 44 x 40 with 16' high ceilings 3 10 x 10 well insulated garage doors 2 man doors and 4 30" x 40" windows. The business side for storing material is 20 x 40 half of that space has 7' ceilings and the rest has 16'. There is one 10 x 10 well insulated garage door, one man door and two windows. Above the business side is space that I plan on finishing into a kitchen/ living room. It is 20 x 20 x 8'. It has one door and two windows. I will most likely heat this area with hot water base board. I have a room in the attic that I plan on making a bedroom and bath room. It is 24 x 18 x 8'. It has two windows and one door.
The garage currently isnt insulated but will have R19 in the walls and blown in up in the ceilings. I have 2" foam under the slab and 2" foam around the perimeter for a thermal break.
The space I am finishing to live in I plan to be able to heat to 75. The Toy and business side I am guessing on 55 normally and plan on using the hanging hot water fan forced heaters to raise the temp if I am out there working.
I want to be able to heat everything with 120* water because I have a Garn 2000 and want to get the longest possible burn time. I live in Central PA where I 'd guess winter temps to average high 20*.
I am looking at having 5 zones plus DHW. Toy, business, kit/Liv, Bed/Bath, Fan forced heaters.
I guess what I am getting at is a am trying to figure out if the 1" pex tubing is enough for the supply and return to the garn? It is I believe is no more than 60' from where the manifolds will be to the Garn.
Thanks in advance for the help.
