I'm picking up an englander 13 this weekend for for my inlaws to install in their basement.My problem is,the ceiling clearance.It has about 11 inches from the drop ceiling to the clay thimble.Can someone point me in the right direction on who to buy from on line.I was going to run double wall pipe to the thimble due to clearances and try to find a double wall to single wall pipe adapter to run thru the thimble-will this work?
If not how can I shield single wall for the horizontal run to the thimble?All the shields I've seen say they are for vertical use only.
One more question.The thimble dumpd into an 8 inch masonary chimney,will this create too much off a draft/creosote problem.Thanks
