I'm looking into having an Quad 1200i installed, right now I have a 25 year old wood burning ZC, Majestic model mbd36. The hearth and mantel were completely redone last year, and I'm not looking to hack them up if I can avoid it. The dealer mentioned I could cut away parts of my ZC's floor and remove things like doors, ceramic brick etc. in order to fit the unit. I'm a little confused about the dimensions required for clearance and how much material will actually be removed.
For instance, the measurement "A" for the ZC install (page 9, figure 9.2 of the PDF) (broken link removed to http://www.quadrafire.com/downloads/installManuals/man_1200i.pdf)
my measurement is 19.5" (this is a rough number as I have yet to remove the ceramic brick backing) the required clearance is obviously 22" - Here's my confusion, from the look of the unit, there are two "layers" if you will, I can see from the top venting that an air pocket exists between the inner and outer layers of the ZC. If the installer was to cut just the inner layer, then I could see there being more than enough space for the 1200i - When then say "rear shroud" do they mean re-using parts of my ZC to meet code, or adding more material on inside?
Any one with a cut/drop insert install experience?
Thanks All!
Thanks All!
