I had my Hampton GCI60 insert (same as Enviro M55 insert) installed yesterday, and this thing cranks out the heat. It was 20* last night outside, so I set the Hi-Low at #2 and it never got below 72* on the t-stat. I originaly set it at #3 with the t-stat at 71* (with a 3* swing), but the heat climbed to nearly 80*, and I never noticed if it went to low mode.
My question is when setting up for Hi-Low do you only set for the Hi temp, and the stove automatically goes into its lowest setting, or do I need to somehow set the low as well?
Should I be concerned if under the 20* outside temp I need to set the Hi temp at only #2.
On another note this is with burning stovechow, which most consider a shoulder pellet from what I'm reading.
The house is 2100sq feet, and the stove even kept the upstairs at 68*, so I'm delighted with the results.
Thanks for the help,
1D
1D
