M
MasterMech
Guest
Dairyman said:I'm back again with a successful report and a few more questions.
I started a fire Saturday night after the cold front moved through, outside temp at 39 winds gusting to 40mph. Used the top down method and it worked great! Loaded her up about an hour in, had the center stone temps at 400 and for what it's worth the outer wall of pipe at 210.
Ten hours later I had a really good coal bed so I moved them to the center and put a small split of walnut on to help burn them down and buy some time. Then I tried Shawn's zipper method and really kicked out the heat. That's when I noticed a huge thermometer discrepancy, the ir gun was at 550° and the stovetop was at 650.
Then last night I did the zipper again and it event crazy on me, she got up to around 650 and I was nervous so I opened the door up to let it cool and that didn't seem to really help.
So my questions are, 1 should I install a flue damper to give me more control? If so how to operate never had one before.
2. Wear should I be concerned on temps, and were sould I be taking them from? The center stone seems to be the hottest so that's were I have been reading from.
3. Which thermometer to believe? The ir seems to be pretty close on everything I've checked it against and stye stovetop low until it breaks 400 then it's high.
Sorry for the long post. Thanks
Emissivity will affect an IR thermometer whereas it will not affect a stovetop. IR Thermos do not get accurate readings from polished surfaces. I would trust the stovetop.
