Lit the first "real" fire in this stove yesterday. Professionally installed in the basement, couple of feet of double-wall with a 90-degree bend to a piece of Class A through the concrete foundation and then Class A up the outside of the house about 25 feet.
Everything went well. I learned that a steel stove heats up much faster than cast iron. I also learned that the stove-top thermometer I bought runs between 150-200 degrees hotter than the IR readings I was getting. (Thermometer 800, IR 600 range depending on location of reading. I'm pretty sure all was well. The only part of the stove that was glowing red was the front burn tube inside.)
Here are the questions:
1) The primary air control lever feels very stiff and hard to move. Is this normal? Can I lubricate it a bit? If so, with what? And exactly where? It looks like the actual linkage is well under the belly of the stove.
2) Do others with this stove find that it is very sensitive to the smallest amount of air? I found that even with just a few splits (very well seasoned ash), opening the air as little as 1/4" had a dramatic effect on the fire? Closing the air would definitely have snuffed it out but I was surprised that I was having to run it virtually closed to keep the temperature from skyrocketing. (Very different from the Hampton upstairs.)
Thanks for any advice.
