New Stove . . . Please help
Vic99
857
MA, Suburb of Lowell
Got my stove Hearthstone Homestead installed on Thursday. Woo Hoo! Now that I have run it for a weekend, I was hoping to get some advice to better my situation. This is my first stove.
MY SETUP:
Soapstone stove venting out of a brick centrally-located chimney on the first floor. Non-cat, 2.0 cu. Ft. firebox. Passed town inspection. Everything seems put together properly.
Two-story, 5 room home. ~1,600 square feet. All 8 ½ foot ceilings except one upstairs bedroom (11 ft. cathedral with a ceiling fan). I plan to get a ceiling fan installed over Christmas.
Unfinished, uninsulated basement.
INSULATION:
Ceiling: R-38 Fiberglass
Walls: Whole house wrapped in 3/8" blue board under vinyl siding (R-2 if I'm lucky), then ~70% of walls are filled with either cellulose or vermiculite(R-13 and R- 8 respectively) . . . the other 30% have neither . . . I'm in the slow process of trying to get some cellulose in that 30%.
Windows: Nearly all are double hung with either 2 glass panes or a glass pane and a glass storm. Two are single pane, French doors are double pane gas filled.
WOOD:
I'm using mixed woods most seasoned 1-2 years. Since I scrounge wood, I take what I can get, but most are oak, willow, maple . . . . and some 80 year old pine that I salvaged from tearing down 2 walls.
PROCESS:
After 3 break-in fires, I started experimenting. Tried to burn 24 hours Sat & Sun.
SATURDAY, when I shut the gas heat off, the house was between 65-67 degrees depending on where in the house you were. I got the stove to peak at 525 degrees in the morning. Most of the day it ran between 350-450. I was home and able to monitor. The living room was mostly in the 80s with the adjacent hallway 70 and the other 2 ground floor rooms at 66-67. Upstairs was 65-66.
Used 2 floor fans in 2 rooms. First blows air into second room. Second blows air into room with stove, but not at the stove.
Outside temp was 25 F, but wind gusted at 30 mph.
I consider this pretty good.
Overnight, stuffed firebox, damped down all way.
SUNDAY, woke up with stovetop at 90 F, and good coals inside, but no wood. Cleaned out the ash pan and put it back properly.
Living room temp 60, Kitchen 52, Dining 54, Upstairs 54 (I know the kitchen insulation is bad and am trying to fix it)
Couldn't get the stovetop above 450 F. Although the living room temp reached 78 ish, all the other rooms only warmed by 2-3 degrees.
Outside temp was 23 F, but no wind.
Tried with and without fans.
MONDAY morning, stovetop was 130 F. Similar situation.
I know I can do better than this . . . . What can I do better?
Many thanks.
When I owned my Homestead, I found that I got the best results when the stove temp was up over 500. When reloading try raking the coals forward, fill it up to the top with medium sized splits, burn on high til the wood is good and chared then turn it down to about 1/4-1/3 air. I like to monitor both stove and stack temps. I think when my Homestead was burning over 500 stove top the stack was 350-400. It may take some time to get use to the new stove.
HI Clown,
That sunday story is strange. The lower max temp could be because you wood was slightly different quality or so. However, why the heat did not go to the other rooms, is a mystery. With fans, the heat should move.
I have had to experiment quite a bit with my fan configuration to get it straight. Took 4 years. Please play with the fans and their location and orientation. Things will improve.
Also, this coming year, spend all your time and money on insulation. Obviously, that needs a lot of attention. If that is improved, what heat you create will be stored better. That way, you don't have to worry about your stove operation too much to get max heat.
Thanks
Carpniels
I'll work on the insualtion and reconfigure fans. I'll try for 500+, but am wondering if it always needed. Good advice.
What else can I do?
