New to the forum
Richie Posted By Richie, Aug 13, 2013 at 2:58 PM
Thread Status:
  1. Applesister
    Applesister
    Minister of Fire 2.
    NULL
    Dec 5, 2012
    2,483
    959
    Loc:
    Upstate NY
    Personally I think Black birch can hold its own next to black locust. But have never done a comparison. I overfired my woodstove once on a straight run of locust. So now I mix it with cherry. I swear my stove was designed for black cherry.
  2. Richie
    Richie
    Burning Hunk 2.
    NULL
    Aug 13, 2013
    157
    48
    Loc:
    Central PA
    Applesister, I loaded up on black birch cause I saw the charts and it looks comparable as far as BTUs and dry weight of a cord. Lifting the black birch at 18% moisture, it is still really heavy. I am lucky enough to have a fireplace xtrordinair elite 44 with a 4.3 cubic foot fire box. With the locust that came with the house I was able to fit 6-7 splits 24"X8". Toward the front half of the insert you can fit 32 " logs so I cut a bunch of my wood into ten inch pieces and filled it along the sides. The insert was literally packed. When the weather was 30 degrees and above outside, I was getting 24 hour burns with the insert damped down all the way. House temp was 70 and when I woke up in the morning house temp was 65. It would literally take the locust 45 minutes just to catch on a nice bed of coals and then about another hour till the cat lit off. When it gets below 30 I would have to load the insert about every 15 hours. There was a little cherry around and was lucky to get 9 hours. I hope black birch is better then cherry because this locust really spoiled me.
    Backwoods Savage and ScotO like this.
  3. Flatbedford
    Flatbedford
    Minister of Fire 2.
    NULL
    Mar 17, 2009
    5,260
    1,265
    Loc:
    Henderson, NV
    Good for you! ...and welcome too.
  4. paul bunion
    paul bunion
    Minister of Fire 2.
    NULL
    Apr 3, 2013
    888
    576
    Loc:
    NJ
    Solid black birch is every bit as good as oak/locust for heat output. It will burn a lot longer than cherry. The only problem with birch is it rots so damn quick. Unless you cut it green it probably has some degree of rot. I got a bunch of it last spring, one guy gave me some green logs, other guy dropped off some standing dead. The standing dead was punky to a certain degree. Anyway If it gets wet and stays wet in your stacks forget about it. White birch wastes quicker and yellow is no better in that respect.
  5. schlot
    schlot
    Minister of Fire 2.
    NULL
    Nov 21, 2011
    771
    490
    Loc:
    Iowa
    Welcome...smelcome. its great to have you here....blah blah.
    One question.....did you bring the donuts?
Thread Status:
