    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
Thread Status:
  1. Jon_Glastron New Member
    Upstate NY
    New to the Pellet Stove Thing and I have a few questions.
    I just purchased a Glowboy 120 and installed it in my finished basement. I have the stove connected to the appliance adapter which is connected to a tee. The pipe then goes vertical in the house for approx. 5 feet. I then have a 90^ elbow and a wall kit and the pipe terminates on the outside about 18" from the house. I have a cone on the end of the pipe.
    All of this was purchased with the stove. The pipe is all BioVent.
    My questions are this. When I started the stove tonught just to test it, I noticed a few sparks now and then coming out of the vent. I've searched around the forum and this appears to be normal. Is my assumption correct? I do not have any plants or anything near the vent termination.
    While the stove was on, I did notice when pellets fall into the fire box, the unit sparks. I am not blowing pellets out of the pot. It just appears as though these are sparks caused by the new pellets hitting the burning ones. Is this OK? I've read my manual and it does mention popcorning, although I do not think this is what I am doing. The sparks do go high enough to hit the heat tube.
    My flame is also quite high and wispy. Does this sound normal or should I turn my fresh air down to dampen the flame?
    Thanks
    Jon
    #1
    Helpful Sponsor Ads!
  2. MCPO Minister of Fire
    Sparks flying out the exhaust would indicate to me that something is not right , possibly too much combustion air pushing unspent fuel thru too quickly. I`d have to think sparks should be contained in the fire box and surrounding areas by design and not any part of the fuel available to burn during and after it`s exit from the stove. That`s simply more lost heat and could present a danger outside too.
  3. Czech Minister of Fire
    Twin Cities, MN
    My understanding is that some sparks coming out of the vent (fly ash) is normal, as well as some sparking when new pellets drop into the pot. As long as the stove is buring efficiently, I don't see a problem.
  4. drizler Minister of Fire
    Chazy, NY 12921
    When I burn corn it tosses all sorts of sooty ash outside. I suppose to a much lesser extent it does it with pellets too. What you are seeing might be dust or sparks burning as they are taken upwards into the flue. Keep an eye on it and I bet you will find its the pellets, not the stove doing it. Before doing anything to the stove change pellet brands for a bag or 2 and see. If thats the case the others will still be alright to use just dirty to burn.
Thread Status:
