New water heater, new wood stove, Now new chimney liner?
sledhead41
19
Circle Pines, Minnesota
I have a masonary chimney just for the wood stove. I bought the house and have used it for 10 years now, cleaned it every year with no problems. I have a 30 year old Sierra wood stove. It uses alot of wood but works fine. I dont shut the air compleatly off at night and have enough coals to start a new fire in the morning. I need a new stove with Outside Air Kit to keep water heater running right.
I just had a guy tell me, "with a new stove I should get a stainless steel liner for the chiminey. People are getting creasult build up and their stoves are not working right." Do the new stoves [non cat] creat more build up? Is the longer burn time due to less air witch would create creasult buildup?
Thanks for the info
Don
New stoves burn cleaner. They create less creosote usually. But it does depend on the wood, the flue and the temps one burns at.
Describe the chimney. Is it interior or exterior? What is the tile flue pipe size?
Newer stoves burn cleaner and put less heat into the flue. This means they need a properly sized flue to get a good draft going. It is also known that most clay and block chimneys are not built to code, so adding an insulated liner adds a great measure of safety and brings the chimney system up to code.
