    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. mywaynow Minister of Fire
    Northeast
    Painted my Defiant as part of an overhaul/rebuild. Used a stove paint from a home center after wire brushing the surface. It took well and seemed to cure fine, however after burning for a month, there are primer gray colored patches in spots where the heat is highest; doors and side where the exhaust is routed. Just poor paint? The stove has not been overfired at all. Ran the stove all year last year with no similar affects.
    #1
    Helpful Sponsor Ads!
  2. Agent Member
    Gillette, WY
    You might have gotten stove paint that wasn't rated for high enough temperatures. I think there are some Hi-Temp paints out there only rated for 750/800F?
    Either way, I wouldn't be surprised if hot spots develop on a normally operating stove.
  3. pen Super Moderator
    N.E. Penna
    was this spray on stuff or brush on? I've had bad luck w/ the spray on doing just this. Repainted the stove w/ brush on and it has been good for years now.
    pen
  4. mywaynow Minister of Fire
    Northeast
    Spray on stuff.
    I see your using an NC30. How do you like it? Been entertaining going that route.
  5. BrotherBart He Who Moderates
    Northern Virginia
    I used Stove Bright on the 30-NC to change the color before I installed it in 2006. Been hot a bunch of times and the paint looks like the day I sprayed it. Stove Bright is nasty acetone based stuff but is what a lot of the stove makers use. When I painted my old stove in the house with it a few years ago I was woozie for days. And it may explain my brain damage. :coolsmirk:
  6. mywaynow Minister of Fire
    Northeast
    Thanks for the explanation on your condition. I will keep that in mind for future posts.
    How do you like the 30NC?? Thinking of getting one as a cheaper option to the quad 5700.
  7. BrotherBart He Who Moderates
    Northern Virginia
    Love it and wouldn't have any other.
  8. mywaynow Minister of Fire
    Northeast
    Is a realistic view to expect a reduction in wood use of 30% going from an older VC to the 30?
