My house had a wood stove in it when I bought it but i Just replaced it with a much newer stove in the same location. it is a bout 6" off of a rock made wall. Is this considered noncombustible and how far should I be off that wall
6" is pretty close. If this is real stone or even cultured stone, then the measurement is to the wall behind the stone. The distance depends on the stove make and model and the type of install (corner, flat wall, alcove). What stove is this and do you have a manual for it? These measurements should be in there and on a plate on the back of the stove.
Does the rock extend all the way through (is it all rock out to daylight), or is the rock built onto a wooden-framed wall? What's important is the distance from the back of the stove to the nearest combustible material. Rock's not combustible, but what's immediately behind it might be, and just rock placed hard against a combustible wall doesn't buy you much insulating value. More details about the construction are needed here. What kind of stove is it? Does it have heat shields installed on it? Can you shoot us a pic of the installation? Rick
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
