    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. Machria Minister of Fire
    Brookhaven, Long Island
    Anyone have one of the Northern Tool splitters (the Powerhorse models!)? They are made in China which scares me. I have a generator made in china that is awesome, better than most. But I also have a bunch of Chinese JUNK.
    Which category does this one fall in?
    http://www.northerntool.com/shop/tools/product_200395407_200395407
    #1
    Helpful Sponsor Ads!
  2. MasterMech Minister of Fire
    Hudson Valley NY
    For $1000 I like the Speeco/Huskee 22 ton unit better. Has an engine on it that is either readily replaced or repaired too. Much beefier beam and cylinder on the Huskee unit too.
    Butcher and TreePointer like this.
  3. nate379 Minister of Fire
    Palmer, Alaska
  4. nate379 Minister of Fire
    Palmer, Alaska
    Looks like a decent unit, though I'd have to see it in person to really say.
    This is what I use for my small firewood business. http://store.aihalaska.com/index.php?main_page=product_info&cPath=11&products_id=30616
    I got it for about $650. Build a bigger pusher and put an 8" tall wedge on it, 16 gpm pump and a 5 gal tank/filter. Runs well, barely uses any gas. I can split 2-3 cords of wood on a gallon!
    The 22ton unit runs about 3x that cost so it was worth it to me to modify the cheaper unit.
  5. mikefrommaine Minister of Fire
    mid coast maine
    I have the 30 ton northern tool. Bought it mostly because it had the Honda engine. No complaint in 4 years. Love the 4 way wedge.
  6. TreePointer Minister of Fire
    Western PA
    +1
  7. Machria Minister of Fire
    The one issue I have with the Speeco/Husky is, it does not have a log cradle (aka log catcher). I really want one. And before you say make one, I do not weld.... so unless one of you will be coming over to make one.... ;)
    Also, I only see one place that sells that unit? Not many dealers?
  8. MasterMech Minister of Fire
    Hudson Valley NY
  9. Machria Minister of Fire
    Thanks MM, that's not too bad! (I know, I'm getting/and am picky, bare with me! ;) ) Not that big a deal, but I don't like how it sits lower than the top of the beam, the Northern one is flush which would make it easy to just roll a log over into position. Also, I would want both sides so that is $75 + $75 + $9 (bracket) is another $160 plus another $35 in shipping. That brings it up to $1100 + 200 = $1300. Over budget again.
    Keep educating me though! Your getting closer! ;)
  10. MasterMech Minister of Fire
    Hudson Valley NY
    The extra length on that table will more than make up for the table being lower than the beam. Trust me. And flush tables are very easy to bend (Except on a machine like the Speeco that has the wedge enclosed inside the beam.) Ask me how I know. :confused:
  11. TreePointer Minister of Fire
    Western PA
  12. basod Minister of Fire
    Mount Cheaha Alabama
    The one I bought(Dual splitter) was made in USA at the time - I guess they have since outsourced them along with their NorthStar brand.
    Haven't had any issues with the engine or carb.
    Added a small piece of scrap pipe to keep logs from falling onto the gas tank and a bypass filter from TS.
    The only "cheap" part is the 90deg plastic hose barbs - I looked into replacement metal ones and I know why they supply plastic, fittings were ~$70/ea.
    Do you have a Northern Tool store nearby? Shipping(truck ship) will add an extra chunk, similar to sales tax.
  13. Village Idiot Member
    No. Va.
    +1 for the 33flame table. My father bought me one for Christmas and I love it. I too was concerned that it being a bit lower than the beam was going to be an issue. It was not. I would not want to have one on each side since it would probably force me to lean to steady the log on the beam. That is a sore tweaked back just waiting to happen.
    I also like how it can be remove for vertical splitting or transportation. I made sure to put it on so the bottom of the table was snug to the beam so it doesn't rattle.
  14. Machria Minister of Fire
    Actually, I should have titled this "Powerhorse by Norther Tool".....
  15. mikefrommaine Minister of Fire
    mid coast maine
    Guess I should have clicked on the link you posted. I thought you were talking about the north star brand.
  16. Machria Minister of Fire
    Not many Northern tool Powerhorse owners around there huh?
  17. Butcher Feeling the Heat
    N. central Ia.
    To add to what others have said, for that money a Huskey/Speeco would be a much better splitter. I also noticed on the specs for the NT brand that it dosnt have auto cyl. return. That would be a deal breaker for me if it means what I think it means.
  18. Machria Minister of Fire
    Can't find a decent place to buy/look/shop for a speeco ?
  19. MasterMech Minister of Fire
    Hudson Valley NY
    You guys have a Tractor Supply on The Island?
  20. Machria Minister of Fire
    Nope....
  21. gzecc Minister of Fire
    NNJ
    Wow, what does that say about the economic situation on Long Island? Maybe they expect it to no longer have a need for tractors? Probably. Must be an incredible shrinking market.
  22. Machria Minister of Fire
    Nothing. I've never herd of a "Tractor Supply" store before this thread. So they never had any around here. We also don't have WaWa's, or Denny's on LI, never did. Yet both of those are all over the place everywhere else. We instead have 7-Elevens, and NY Dinners. Has nothing to do with economy.... just different market shares for different brands. There are tractor and equipment supply store's here, just not under the name/brand "Tractor Supply". ;)
