JimboM said:In the case of carbon monoxide, the prudent thing to me would be put them at the level that you are going to be breathing. In the bedroom - roughly pillow level. Near the stove - roughly the headrest level on a tilted back recliner. In the bar - the level of the brass foot rail. ;p
http://Boozie said:How close or far should the CO monitor be from the stove? And, should it be up high or low or does it make a difference?
Thanks
Hankjones said:I've got one of those detectors that tell you the level CO, but I've never seen it above 0.... Humm makes me think maybe I should test it out. Any ideas?
mydogspot" date="1296[b said:686603]
Do you have a garage? Is your car parked in it? If so, take the detector out to the garage and start up the car[/b]. Your alarm should start screaming in 30 seconds.
DOUBLE DITTO!Shari said:JimboM said:In the case of carbon monoxide, the prudent thing to me would be put them at the level that you are going to be breathing. In the bedroom - roughly pillow level. Near the stove - roughly the headrest level on a tilted back recliner. In the bar - the level of the brass foot rail. ;p
:lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
xman23 said:Just last week I purchased new set of wired smoke detectors to replace the ones I had that have been going off with temperature changes. On the level with the stove, I got a dual detector, smoke / CO, $47 compared $14 for the smoke only. Why not it can't be a bad thing to have CO. But we never had a CO based on my non scientific, uncorroborated theory that we don't need one. My theory, the heat is electric base board, no odorless CO from them. The wood stove, if any of the exhaust gasses escapes into the house you know it, far from odorless. So where does the odorless CO come from. Maybe I'm missing something here, what do you guys think, are we lucky to be alive.
Tom
Thanks
Remkel said:We have two CO monitors in the house- one is mounted on the side of our lower cabinets at the top of the basement stairs, the second is mounted at the top of the stairs leading to the second floor bedrooms.
Interesting question about CO being up high or down low. CO has a vapor density of .97 (air=1) which means that it is lighter than air, but not by much. This means that CO will tend to stay at the level where it is released or tend to rise slightly. It will also move with the air into which it is released, so hot air rising will potentially move the CO higher, but as the air cools it may drop. My monitors are at waist height with the thought I would split the difference between the two. I also have friends that put them in wall outlets closer to the floor and have had them go off at that level.
I would be interested in anyone else's thoughts on the matter.
colebrookman said:http://Boozie said:How close or far should the CO monitor be from the stove? And, should it be up high or low or does it make a difference?
Thanks
www.homesafe.com/coalert/detect.htm
Good info here. Be safe.
Ed
Wood Duck said:The local volunteer fire department came out this fall, checked our smoke detectors, and gave us some new ones. They told me the CO detector should be on the ceiling near the bedrooms, not in the room with the stove. In my house, the stove is downstairs, the bedrooms upstairs.
Tom
earlll said:Correct? CO is ambient & neither sinks or floats as a gas due to its molecular weightJimboM said:In the case of carbon monoxide, the prudent thing to me would be put them at the level that you are going to be breathing. In the bedroom - roughly pillow level. Near the stove - roughly the headrest level on a tilted back recliner. In the bar - the level of the brass foot rail. ;p
PyMS said:earlll said:Correct? CO is ambient & neither sinks or floats as a gas due to its molecular weightJimboM said:In the case of carbon monoxide, the prudent thing to me would be put them at the level that you are going to be breathing. In the bedroom - roughly pillow level. Near the stove - roughly the headrest level on a tilted back recliner. In the bar - the level of the brass foot rail. ;p
Yes. The molecular weight of CO (28 amu) is similar to that of N2 (nitrogen gas) with just a few thousandths of 1 amu difference. If it were to separate out on the basis of this minuscule difference from N2, O2 (oxygen gas; 32 amu) would be separating out from N2 much much faster....
Alas, you can't get more oxygen by just laying down on the floor.....
In very cold conditions (i.e. minimizing spontaneous convective air movementa), however, and in the absence of external air disturbances (wind, fans, people walking through, etc.), layers from any of these gases that are carefully released at different heights might take quite awhile to fully mix
Henk
