Older Fisher Stove clearance question
TIM111
3
Coaly do you know the clearance measurements for a grandpa bear stove (1977-1980 not positive what year)?
Assuming you're in the US ; 36 inches to combustable. (48" Canada) This is from NFPA 211 Standard which most codes adopt. There is a section in the standard for clearance reduction that specifies the contruction and air space behind and below a radiation shield that reduces the clearance by 66%. (36" Canada) Pipe clearance can then become a factor, being 18" for single wall, 6 inch for double wall in the US. (Canada refer to CSA B365)
The diagram in the link below is floor protection, not wall clearance.
https://www.hearth.com/econtent/index.php/articles/wood_stove_clearances_installing_it_safely
