Question is should I try to tuneup a stove built in 1999 or simply replace it? More information follows. Has the efficiency of the stoves increased that much in the last 10 years?
We have purchased a home with, what seems to be a nice wood stove. It is a Dovre "Cape Cod". Manual is http://www.quadrafire.com/downloads/installManuals/man_capecod.pdf
The previous owner did not maintain it at all but used it heavily. The chimney sweep was a bit shocked by the buildup and stated it had probably never been cleaned. It seems to me, I have no experience with wood stoves, that when I shut the door and opened the primary air controller the fire was not receiving enough oxygen.
I cleaned it out completely, took off the top and removed a bunch of buildup off of the Kaowool. The Kaowool had ripped, folded etc and seems a bit delicate and thin. Once again I have no experience, that is just my impression.
My next possible step is to dig in further, replace the kaowool, try to remove the manifold tube (to clean them).
Should I bother or just work on replacing it?
Thanks,
Bob
Thanks,
Bob
