    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. Rick S. Member
    Northeast Indiana
    I just switched from an ahs coal gun to an ahs e-140. The boiler works as planned, but I can't enough water to circulate through the radient floor pex. All the air has been bled from the pex in the floor so I don't have an air lock. I have the same circulater pump[Grundfos 15-42F] that I used with the coal gun and it worked just fine. I now have two mixing valves[Honeywell am-1 series] and only had one with the coal boiler. Do I have a big enough pump to handle two mixing valves? All plumbing between the boiler and the floor manifold is 1 inch copper. The pex in the floor is 1/2 inch, about 2200 feet.
    #1
    Helpful Sponsor Ads!
  2. BoilerMan Minister of Fire
    Northern Maine
    Can you give a diagram of what you have, sounds similar to a system I put in with a pellet boiler. I used a Watts 1170. I used a Taco 008 for the circuits, 300' 1/2 loops.
