Oregon chain grinders
Stephen in SoKY
333
Southern Kentucky
I can pick up 6-8 chains per week from from a friend and neighbor that logs on his own. All chains will be 3/8 full chisel, so I won't have to constantly change angle/size between chains. I assume I'll be able to set and run? I plan to buy either the 511AX: http://www.northerntool.com/shop/tools/product_200354876_200354876 or the 510A: http://www.northerntool.com/shop/tools/product_200381699_200381699 unless someone here has experience with another grinder I should consider? Can anyone comment whether the 511AX is worth the extra $100? Is Northern Tools price in line with other sources you're familiar with? Will I have to change wheels to adjust rakers with these models? If yes, how about a cheapo Northern Tool grinder set up to just grinder rakers? Thanks very much for your input.
Thats 2 of the very best grinders out there. I have the 511a Zap has the ax. The ax is a new version and has some fancy up grades if you want later. Cant go wrog here!
Even a girl can do it... http://youtu.be/5XLq5zemMss
Like Smokin said you can't go wrong. The shop that use to do mine had a seperate sharpener setup for the rakers, I just file mine.
zap
Even Gamma!
swampy
Thanks for the replies. Since I won't be switching between chains, does anyone see the $100 advantage to the 511AX?
Might be just as fast for you to hit the rakers with a flat file quick rather than a second grinder. An old bar is all you need to hold the chain.
I use the old bar trick, but instead of the file I use the 150 grit sanding flap disc on my 4" angle grinder for the rakers. I usually already have it out to dress the bar so I also use it on the rakers....
Only thing I would consider is one of the diamond grit wheels. They are expensive but with any higher volume you will appreciate the fact that it will not over heat the cutters.
