Osburn 1050 wood stove baffle position
Stawb
1
Coplay, PA
Hello,
Does anyone know the correct position of the1050 baffle.
It has an offset, triangular, welded reinforcement bar running the length of the baffle.
I know the bar side goes topside.
What I don’t know is does the low or high side of the triangular bar go toward the back of the stove?
Thanks in advance,
Stawb
On my Osburn 1600 it faced up. There should be a lip on either side of the angle to hold the baffle or bricks depending on model. You have to put the front and back bricks in first then the middle has to be slid up over the angle then slid in. Then push everything as far back as it will go.
