Outside Air Intake for wood stove in a highly sealed new home
hyacinths
2
Hi,
We just built a highly sealed new home near Burlington, VT and will be installing a wood stove. Our neighbor also built a new well sealed home with a woodburning stove with outside air kit. Within two weeks my neigbors stove was rusting on the inside. It seemed that during this two week period in the fall they did not burn the fire regularly and when the stove was cold, outside air was moving into the stove, warming up due to the homes 68 degree temperature and the humidity was condensing in the stove and causing the rust. I believe the air movement was accelerated because we live in a relatively windy area. They could not figure out a way around this problem, so they replaced the stove and tore out the outside air kit.
My question, is has any one had a similar experience and found a solution?
I was wondering if there might be a valve type mechanism that can be installed in the chimney connector between the stove and the ceiling that can be manually opened when I start a fire, but that thermostatically closes when the fire goes out. This, I believe, would eliminate the problem of outside air free flowing through the air intake piping, stove and up the chimney and leaving rust causing moisture in the stove.
Many thanks in advance.
Why not just block off the air intake outside and put a note in the stove, when you open the stove to start a fire you will see the note and know to clear the intake, thats as automatic as I can think.
When I lived in Quebec, we had a wood stove installed with an outside air intake that I could close off with a handle. Once the stove door was closed, it was the only way the stove got fresh air. I didn't have any condensation problems because I always closed the intake when not burning.
Your neighbor should have a Hearthstone anyway, living in Vermont, with enamel of course, no rust.
hyacinths-
Welcome, Welcome to the wood burning nuts forums !
Wife and I built a SIP panel home- very well insulated too. I would think you might want that OAK (outside air kit) installed for your stove because w/o it- you run the risk of not having enough free breathing air' in the house, and it will just make the stove run better anyways.
I have an OAK on mine- and also a window near- so I just crack the window a little when I'm running the stove.
I haven't had any problems- but I like the idea of a shutoff as the other writer mentioned too.
