    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
Thread Status:
  1. QandA New Member
    Question:
    I have a safety question related to the use of an outside air intake. The cabin I am planning is to be built with 6" walls, insulated windows and the like to withstand the cold Northern Minnesota winter. The point is that this building will be "tight". I am planning on installing a wood stove. The concern, given the construction characteristics of this building, is that the stove will consume an inordinate amount of oxygen inside the building thus posing a safety problem. Would you recommend outside air intake for new construction or am I just being paranoid?
    Answer:
    Yes, because of your climate and the tightness of the home, an outside air source will help make certain that your stove works correctly. Another option would be to install an air-to-air heat exchanger into the home. This assures that the air in the home will be fresh.
    #1
    Helpful Sponsor Ads!
Thread Status:
