Oval To Round Liner Cleaning
I'm thinking a regular bush that can clean a 6inch diameter pipe would do the trick. Hopefully, the brush is flexible enough to pass thru the oval passage way...
Am I answering my own thread? :grrr:
Not sure, but.....
My 6" nylon brush would very likely not go into the oval section. Too stiff.
But, they're fairly low priced, and the oval section is just a very short run, so you might be able to get a smaller brush and work it around a little. Probably be adequate.
