Plastic Smell when lighting stove
Blowndiffuser
38
UK
Hi,
Bit of a strange one, the last five or so times when I've lit my burner its been given off a plastic type of smell which only lasts for about 15 minutes and then disappears once the stove is coming up to temp. I've given it a really good clean (to rule out dust) and removed the baffle plate and cannot see any signs of a build up of creosote around the flue pipe. The stove has been running all winter, but not every day as its been fairly mild. Always have a hot burn with wood under 20%. I know that in milder conditions now spring is upon us, the draw is not as strong but I'm stomped as to what could be given of the smell. I've got the installer coming out next week to take a look and give it a sweep which will be its first once as its only been installed for 8 months.
Any ideas?
Describe your install in more depth. Is it possible that something fell against the pipe in the attic or wall pass through?
The burner is installed into an existing chimney that has been lined, insulated and fitted with a cowl,I also have a register plate which would prevent any fumes from coming down into the living area if something was leaving against the pipe further up the chimney. So its very unlikely that a foreign object has found its way in.
Are there any children in the house?
If it not an insert, you might want to check around the stove for Lego pieces, plastic cars, or something to that effect.
I have an insert but am always finding stuff from the littlest one on the mantle or right in front of the stove.
If it has convection loops also look for something pushed inside the vents. Especially if the stove is often cool.
KaptJaq
That was my first thought and I did find a small piece of Lego under the stove but it wasn't that giving off the smell. It's strange that the smell disappears once it's up to temp
Yeah there are
It might be worth looking carefully for a lost toy, another lego piece, small plastic character stuck behind the stove. It may be wedged behind the rear heat shield. Or perhaps it was the lego piece and the heat made it drop out to the floor?
So after cleaning the top of the baffle plate and two hot fires, I lit the stove tonight and the smell is getting milder and not lasting as long. My thinking is that whatever is causing the smell is slowly burning off.
