POOR venting Lazy flame agian EF3 Enviro
karayj
37
Franklin
So I noticed my ash pot fills much faster than normal and when I slide the vent adjusting bar there is no change .
I have an enviro EF3 I have cleaned the pot /pulled the over flow tray and emptied it,
I loosed the screws to slide open the 2 round circular blanks and looked inside and they are not clogged..
Remove the steel at the back of the fire box . remove the 3 steel panels behind it
clean the passage to the slide . work at it get all the ash out ( you will find this
area PLUGED with ash) . Remove combustion fan clean area behind you will see
slider and outlet to vent clean clean clean. Clean the fan reinstall everything should be
good to go
If you don't have a manual here's one
http://enviro.com/custom_content/docs/manuals/C-13839 Instruction EF3 Domestic Owners Manual.pdf
